My '00 Z28 at the track- 11 sec run
http://videos.streetfire.net/video/0...ab00201949.htm
Car is a 6 speed w/ a mild cam, intake, exhaust, 4:10s, DRs.
85ish degrees out, decent track prep.
I was using 255/60/15 MT ET Streets. I dropped them down to 20 psi and it was still difficult to get them to hook.. needed lots of clutch slip. 60' was 1.78.
I wouldn't recommend running the ET Streets if they are the tires you will be using every day. A set of mine only lasted 2500 miles of easy daily driving and 2 trips to the track.. Make sure you have some street wheels.
