just bought a ported tb and...
If you can find someone who has a spare TB or just the blade, you can fix your idle problem. That extra hole, along with the other much larger drilled hole, shouldn't be there. You can replace the blade very easily, I believe its a T-25 star bit on those two little bolts, flip the shaft open, and the blade will slide right out.
If you still don't feel like using that TB, I will port another one for you at no charge (you just cover shipping both ways) to help you with your troubles. I hate seeing people get screwed over something so simple as a friggin ported TB.
PM me if interested. Take care.
If anyone wants this POS let me know, I may just give the damn thing away since it's caused me this headache.
Maybe the epoxy is cosmetic, but a TB with a hole all the way through the side that has been filled in with epoxy is NOT in great condition as advertised. And if you buy a TB that is advertised in great condition you shouldn't have to tune for modifications that have been done to it, like the throttle blade hole.
