air in, boom, air out. i want synergy. confused!!
the big question is, what order should i plan things? choose heads, design exhaust, then grind cam? i feel like there should be some step where i calculate exactly how much air i'll be getting with the ported 90/90 and head combo, and how much air i'll be pushing out with the exhaust setup. i feel like there should be a step where i figure all that out before i grind the cam.
AND i want to do a cold air/ram air setup (dunno which it falls under) in the style of madman's big gulp. it can't be that hard. sheet aluminum and a couple welder buddies. but i dunno if that would need to be factored into the cam?
and how do you measure this? do dyno runs with a "closest guess" cam and then refine the specs to match your setup perfectly?
now, i want to make a high 400 rwhp. like 470-490.
here is what's already on the car, power wise
from front to rear
slp lid
stock tb
ls6 intake
ls6 pistons
comp cams 238/242 .610 .605 112lsa
241 heads
hooker super comps 1-7/8 headers
pacesetter offroad y
custom fab from there back, no cats, cutout after axle. not sure of diameter
i am planning on replacing all the respiratory organs. and yeah, supporting suspension, clutch, flywheel, driveshaft, rear end. tires. as far as what's on it now, what can i keep? what doesn't need to be replaced? im hoping the headers are good enough for high 400s. that might be it though. =/
some insights/suggestions/opinions are greatly appreciated.
from front to rear
slp lid
stock tb
ls6 intake
ls6 pistons
241 heads
