LS6 intake swap question
I am about to do the ls1 intake swap. Can I just shave the bottom of the intake with my dremel and use my coolant hoses that are already there instead of changing the hoses?
Yeah, by grinding the ribs off the the ls6 intake, making it flush with the bottom of the intake you can still use the stock coolant lines. If you do a search you could actually find the exact ones you need to shave off but I just did all of them. Just a little extra weight reduction
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Heres a link
https://ls1tech.com/forums/showthrea...532&highlight=
I started a thread on this a while back if you look there are two links provided one show exactly where to chisel the fins.
