is my clutch fluid boiling?
#42
I'm having the same problem with the pedal sticking to the floor in hard shifting at WOT (2-3). First switch to DOT 4 bc it has a higher boiling point than DOT 3. Then I would recommend replacing both the slave and master cylinder at the same time, bc who wants to do it all over if its the other malfunctioning. Also think of replacing the clutch with a good one as well, bc then you know that you shouldn't have to deal with clutch problems for a long while.
