LS3 in 4th Gen f-body
Has anyone used a th400 behind a LS3 engine and if so what will I need to get this to work ?
Motor is carb based set-up , if that matters
Need some Help !
Need some Help !
https://ls1tech.com/forums/conversio...onversion.html
Do a search and you will find more threads like this 1.
Thanks for the assistance, I'm also in need of Information regarding if a th400 will work on a LS3 ( bolt -up ) and what is needed or has to be done for this to work.
Thanks again for starters
The Gen3/4 engines have the engine-trans bolt pattern similar that a Powerglide will bolt up to an LS9.
Read this sticky in the Automatic section to find out how:
https://ls1tech.com/forums/automatic...-you-want.html
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
