What kind of cam is this??
What kind of power will this make and in what areas will it make it and what size stall .510/.520-236/238 @.50 and 286/287 normal with a 110 lsa i got offered one and would like to know the range of power and if itd be choppy and what size stall doesnt seem like much but was told itd be good for about 35 hp
Thats a pretty decent size cam. The idle will depend on the tune you get with it. It will probably be really choppy though having such high duration and being on a 110 lsa. It will make its power higher up in the power band.
THat's a prety big cam and would drastically change the way your car runs. it would be very chopy and would require a dyno tune and probably a 3k stall to even be drivable. To fully take advantage of that cam you would also have to get larger injectors, and ported heads would also be recomended.
What do you want from a cam. 35HP is easily gotten with a much smaller cam. Something like the 224 or 228 on a 112LSA would have a good lope and would make very good power for a daily driver. Don't buy someone elses junk just cause it's cheap.
Re'
Re'
