Vibrating LS1??
Old Jan 26, 2009 | 01:40 PM
importkilr99z28's Avatar
Default Vibrating LS1??
I have a 99 z28 A4 and i seem to get a vibration at around 1600-1800 rpms. It does it when i drive, and also does it in park when i hold the throttle at a steady RPM. I know this cant be normal, but has anyone else had this problem? It feels like it pulses if that makes sense, it will vibrate enough to shake the steering wheel, then smooth out, then vibrate some more. The engine only has 60k miles. I have no idea where to start, help?
Old Jan 27, 2009 | 08:53 PM
elias_799's Avatar
mine does that too, every time i start it in the morning the steering wheel vibrates a little and then once the car warms up and the idle drops to around 600rpm from 1000 the shake is gone. i don't think you should be too worried about it. good luck
Old Jan 27, 2009 | 10:04 PM
twitchtwice's Avatar
its a muscle car man, its okay.
Old Jan 27, 2009 | 10:16 PM
01ssreda4's Avatar
maybe bad motor mounts/tranny mount
Old Jan 27, 2009 | 10:45 PM
elias_799's Avatar
^^+1 i have a torn engine mount and that is probably why it vibrates, but it is nothing too big
Old Jan 28, 2009 | 05:55 PM
01ssreda4's Avatar
when i pulled mine to put polys in the rubber ones were shot to hell.
Old Jan 28, 2009 | 10:59 PM
elias_799's Avatar
i am just going to get solid ones and not worry about it anymore .
