LS6 intake and Engine valley cover
I recently swapped the intake from the LS1 version to the LS6 as well as doing the engine valley cover everything works absolutely fine and it's much cleaner now, the only problem I'm having is with the SES .. I've done a bunch of research and have seen conflicting stories about what to do about it.. what's the normal thing to do in this situation? I've read where it can be edited out, is this the only way to get this legitimately fixed? The pump is completely removed and I'm thinking that empty connector is what's throwing the code.. is there a resistor that can be used in place of the pump? I'm a bit confused!
Re: LS6 intake and Engine valley cover
noone knows anything about this? wait lemme check .. this IS LS1 tech right? C'mon someone's gotta know sumpin'!
Use LS1 Edit and cancel the EGR code.
Hey no flames here... if you noticed I finished with a smiley. My first post states that I did do the research.. which I always do BTW (here/LS1.com and a few of the others as well as the how to sites and so forth). It also states that I've found conflicting fixes for the same problem and was looking for some friendly advice. I now have it and thank you. PS.. you are correct this is a good board. I wouldn't have been frequenting it for the past 6 months if it weren't. keep up the good work
