motor mount clamshell bolts - which lube?
Since antiseize is used for header bolts, do I use antiseize for the bolts that mount the clamshells to the block? Or do I use Loctite or moly lube? Here's a pic of the bolts I'm talking about if that helps:
![](http://zigzautonotes.googlepages.com/clamshell_bolts.jpg)
Just want to do this right; thanks again for any help/advice
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
Another thing on the header bolts better get locking header bolts or they will be backing out on you. way easier put them in now than later cause they keep backing out on you.
