confused
Old Mar 6, 2009 | 09:18 PM
99ls1muscle's Avatar
Default confused
aite so this is where im at rite now.. i just purchased a used ls6 intake without egr. so from what i hear all i need is to get a block off plate to cancel it out. now im also ordering some new long tubes this weekend and wanted to make sure that, since im blocking out the egr in the intake i dont need to get the headers with egr rite?? i could just tune it out anyways? since i have a freindly smogger around here. sorry if it doesnt make to much sence... newb
Old Mar 6, 2009 | 09:21 PM
waldershrek's Avatar
Yes, if you get the block out plate you will be fine with the non EGR headers. Just get a tune also
Old Mar 6, 2009 | 09:27 PM
ok just wanted to make sure... thanks for the quick response!!
Old Mar 6, 2009 | 09:28 PM
Brian M's Avatar
whats the block out plate i have no egr and i dont think i have a block out plate
Old Mar 6, 2009 | 09:33 PM
If your car didn't have EGR originally then you wouldn't have need for one. It is a part designed for cars that had it originally but removed it for what ever reason (usually race headers with no emissions fittings).
Old Mar 6, 2009 | 10:44 PM
nemss1's Avatar
if anyone needs blockoff plates, speedinc and texasautocraft.com have them
Old Mar 7, 2009 | 02:52 PM
one more question, do i need to purchase the rear o2 extentions??
Old Mar 7, 2009 | 03:05 PM
tacklebox's Avatar
With longtubes? Yes.
Old Mar 7, 2009 | 03:08 PM
tacklebox's Avatar
Get the O2 extentions and use them for the fronts. Have your tuner delete the rear 02's.
Old Mar 7, 2009 | 03:28 PM
cool thanks alot!!
Old Mar 7, 2009 | 03:35 PM
Well the front ones the car needs to run. It uses those to determine how rich the exhaust is and adjust the fule/air/apark accordingly. The rear ones are for emissions purposes only and do not affect performance. Most guys just have the rears tuned out when using longtubes
Old Mar 7, 2009 | 07:00 PM
nemss1's Avatar
if tuning rears out, u can plug them with oil drain plug for a toyota (18mm x 1.5 pitch). can get these at advance auto for a couple of bucks
