Code p0420
Code p0420
I got this code a little while back after driving my car for the first extended period of time after a winter semi-storage. The same gas was in the car for probably 2.5 months. The readout said:
-Catalyst efficiency low-bank 1
-Catalytic converter defective (failure due to #2,3 or 4)
-Engine misfire or running condition
-Large vacuum leak
-Engine Oil leakage into exhaust-valve guide, seals, piston rings.
I cleared the code Because I found this to be impossible and retarded. Car runs excellent. I changed the oil about 75 miles before this code illuminated. It illuminated after cruising at 40 with about 5% throttle for a while.
I just chalked it up to bad gas.
Any thoughts?
-Large vacuum leak
Any thoughts?
