maf ends question
Old Oct 29, 2003 | 11:11 AM
Camaro SS 2002's Avatar
Stick with the whole Stock MAF IMO.
Old Oct 29, 2003 | 08:47 PM
unit213's Avatar
Administrator
I like how the guy who started this post didn't even show his face again after the initial post. We have all this good info in here and he's no where to be found.
Old Nov 1, 2003 | 02:16 AM
faethor's Avatar
some of these guys are right. even IF your car likes it, it's not worth destroying other functions over 2-3 h.p. that you wont even feel. that's why i laugh when people get into exhaust performance debates. pick what SOUND u like, because the difference in performance is negligable. what, 3-4 ponies? yeah, SURE u can feel the difference. back to the original question; the decision is painfully obvious. use your time and money towards better upgrades.
Old Nov 1, 2003 | 05:53 PM
unit213's Avatar
Administrator
I agree with you faethor except when it comes to Flowmaster exhaust for fbodies. It is absolutely horrible in comparison to the rest. Excluding that one, all the other catbacks basically flow the same so you should go with the sound you like.
Old Nov 1, 2003 | 06:04 PM
samz28's Avatar
unless your maf is reaching max output , there is no reason to modify it. The ecu uses the maf for alot more than fueling. Datalog your maf with efilive and see if it needs it.
Removing the honeycomb is silly on a maf. That just causes turbulence and incorrect maf readings. They didn't put them there to collect leaves lol
Old Nov 1, 2003 | 07:56 PM
SLIDER's Avatar
Hey 02 SS in Pasadena CA. Have you dyno'd after adding Magnaflow? I have an 02 SS 6M as well, and am thinking about upgrading stock exhaust, but need some dynoproven results before spending $$.....thx
Old Nov 1, 2003 | 07:59 PM
slow's Avatar
if you have the stock exhaust, (not slp dual dual, ect)
you will pick up a little power from exhaust.
But like was said above, buy exhaust based on sound, and the hp is a bonus.
if you need power, headers are where you should spend the money, (and a cutout)
Ryan
Old Nov 1, 2003 | 08:10 PM
I will be heading to the dyno in about a week, I will let you know the results. I read somewhere that the Magnaflow catback dynoed 1 less HP than a cutout. How true that is, im not sure...
Old Nov 1, 2003 | 08:13 PM
slow's Avatar
a friend picked up around 10-15 hp from a flowmaster, going to a magnaflow.
I have also heard the 1 hp magnaflow vs cutout number before.... (still deciding if i should weld a cutout on my magnaflow before i install it... )
Ryan.
Old Nov 2, 2003 | 10:12 AM
unit213's Avatar
Administrator
You know that GM stopped using the MAF screen right? I believe on the LS6 MAF. Could be wrong there, but the screen in LS1/LS6 applications is unnecessary.
Old Nov 2, 2003 | 11:07 AM
samz28's Avatar
Line pressure isn't the only thing affected in the ecu by an inaccurate maf reading. load up ls1edit and look at all of the parameters skewed by maf offsetting.
Old Nov 2, 2003 | 11:16 AM
  #32
slow's Avatar
you want the honeycomb on any maf situation where there is not straight air coming in to the maf.
the f-body this is the case, you its a good idea
the trucks,and vette, have a striagher airpath, so it is not as big of a deal.
Ryan
Old Jun 15, 2011 | 03:42 AM
  #33
AiDRocks's Avatar
The search button does work! This is some good info.
Old Jun 29, 2011 | 02:52 PM
  #34
jesse anaya's Avatar
what should i no about power shifting so i dont damag rods tranny cluch
Old Jun 29, 2011 | 03:15 PM
  #35
Tommyv8's Avatar
You should know that it doesn't have anything to do with your MAF ends.
Hey, what ever happened with that whole 9/11 terrorist attacks deal? Did they ever catch the guy who did that or what?
