Cloudy headlights.
:edit:
Ask and 'ye shall receive
How to fix cloudy/yellow headlights
take 600 grit wet to the lights and make sure to sand only one way from left to right, then take 1000 grit the same way, then take 2000 grit the same way, after with a heavy compound and your cloth pad take it to the lights, then get a lighter compound lowest abrasive posible with a foam red pad, then finish off with some wax i have some pix here of my buddies i did i the pixture you will see i compare them to the lights on my car his were 10 times worse
http://fbodyinclive.30.forumer.com/i...?showtopic=531
wiped em with a tack cloth and sprayed em with about 3-4 coats of clear.
I'm not a heavy buffing fan.
