DD cam?
Old Apr 21, 2009 | 12:22 PM
ChaSSe's Avatar
Default DD cam?
Hey guys I want to keep my car streetable but I want it to have a bite as well.
I was wanting to get a cam, but I didnt know what to get that would be a good DD cam, and one that doesnt need a tune.
Mods are:
SLP CAI
SLP DD (soon to be something else)
Thanks guys!
Old Apr 21, 2009 | 12:32 PM
DANOZ28's Avatar
im clueless about a upgraded cam without a tune. my ls6 runs so smooth you cant even tell i've got a cam, 600 rpm idle, 5750 peak hp, of coarse it will rev higher. the negative is low dyno #s. with any cam you should upgrade your springs. i've heard stock springs float or bounce at 5800rpm. i'm thinking of upgrading my cam to 224/228 dur, 570 lift on a 114 or 115 lsa. just my 2 cents, under engine internal please read the cam sticky. call our sponcors for better opinions. cheers!
colby72olds's Avatar
Probably a hotcam or ls6 if you don't want to get a tune.
Why no tune? I ordered a VRX3 for my DD
Old Apr 21, 2009 | 01:01 PM
fccs's Avatar
You basically need a tune for ANY camshaft WORTH swaping. If you plan to swap cams and go through all the work to begin with for a cam that won't require a tune to run great... then chances are the cam is so small that it isn't worth doing PERIOD. Ether get a decent or mid size cam like a 224 or a 228 or a little bit smaller and get a good tune or don't bother spending the money to get one at all. It just won't be worth it.
Old Apr 21, 2009 | 01:09 PM
Z28SteveA4's Avatar
the ls6 is the one u want if u dont want to do retuning but if ur doing a cam might as well make it worth it. I believe that cam is just not worth doing but that just me. If u want a basic cam that is good for power and streetability then do the 224 and get the car tuned
Old Apr 21, 2009 | 02:47 PM
SOMbitch's Avatar
Headers before you even think about a cam unless it is a Thunder Racing cheatr.
Old Apr 21, 2009 | 02:55 PM
ChaSSe's Avatar
Thanks guys for the input. I just don't want to spend the money for a cam then a tune and then if I decide to do heads and something else paying even more money for a tune..
Old Apr 21, 2009 | 06:40 PM
fccs's Avatar
Well like said above, if your thinking of doing a cam and ur stock otherwise then worry about boltons first or you'll completely waste your money. AFTER you have headers back full exhaust and what not, THEN pickup a cam and get it all tuned at once. Thats worth around 400rwhp, if you want heads later down the road.. well you will be spending more money anyways so either do it all at once or just let it go for now and do it later with a tune.
Old Apr 22, 2009 | 02:08 PM
SOMbitch's Avatar
Retunes are cheap if you use the same tuner who originally tuned it........
Old Apr 23, 2009 | 10:37 AM
99blancoSS's Avatar
Most of the time but not always. Make sure you check with the tuner first. I know of a few who charge full price everytime they touch your car
Old Apr 23, 2009 | 11:45 AM
ChevyRyda99LS1's Avatar
damn those are the rip off artist
Old Apr 23, 2009 | 11:49 AM
LS1BLKSS's Avatar
Banned Village Idiot
get headers 1st!!! look into the MS3 i DD mine, drives smooth and the power is there when you need it!!
Old Apr 23, 2009 | 11:59 AM
406malibu's Avatar
dont forget you can't get JUST a cam, you need supporting mods, such as better oil pump, timing chain, injectors, springs, headers, and yes... tune. way your car sits it'll cost 1k to get a cam in there and be safe/run right.
Old Apr 23, 2009 | 12:01 PM
LS1BLKSS's Avatar
injectors?? im running stock injectors and my car was running fine... gave it some monkey juice 150 shot and still ran fine
Old Apr 23, 2009 | 12:06 PM
406malibu's Avatar
You also have 28 lb injectors... not to mention unless that was a 150 dry shot, it has no bearing on your injectors...
my injectors are at 100% duty cycle with just bolt ons /tune
damn 2000 for coming with 26 pounders
Old Apr 24, 2009 | 01:32 AM
ChaSSe's Avatar
O sorry I forgot to mention its an 01 M6
Old Apr 24, 2009 | 03:14 PM
brianfromhawaii's Avatar
i have a 244/242 daily driver. it just lopes at idle and such
Old Apr 24, 2009 | 08:17 PM
01ssreda4's Avatar
exactly, dont go cheap, do it right. if not take your $200 to burger king or some ****.
Old Apr 24, 2009 | 09:24 PM
ULTIMATEORANGESS's Avatar
id get LTs first but theres many nice cams for ls1s that are very streetable.
Old Apr 24, 2009 | 09:41 PM
01SuperSport's Avatar
Yea bro I'd get some bolt ons first. Do it right and get the cam after. You NEED to get a tune for it to really work at full potential. Longtubes are hella fun man especially with a cutout. TRUST ME!!!!!!!!!!
