is the trans go shift kit easy to install??????
I'm pretty sure the shift kit is actually above the valve body. You'd need to drop the pan and take out like 15 bolts that hold in the valve body. The bolts are different lengths, it's very messy and the bolts will need to be torqued down to a specific ft/lb. Maybe 7 ft/lbs, i can't remember for sure, the pan needs to be torqued down too. It might be a bit complicated for some people, i don't have a torque wrench so i didn't bother.
