ls6 intake aftermath problem
Old May 28, 2009 | 03:49 PM
Bad Blue WS6's Avatar
be sure your spark plug wires are fully seated,,, i think they click twice, but not sure if that 2 clicks is on the plug, coil pack, or both
Old May 28, 2009 | 04:11 PM
Keith_Shapiro's Avatar
just did the swap and i havent had a problem with it, mine is also a 98. i also had mine re-tuned immediatly after, dont know if that has anything to do with it!
Old May 28, 2009 | 05:00 PM
71-Camaro-98's Avatar
Glad you got it started... As far as the misfire, check your injectors...
Old May 28, 2009 | 10:27 PM
raysadude's Avatar
maybe the tune has something to do with it, i'm thinking that with better intake means more air isn't that going to make the car run leaner?
Old May 28, 2009 | 10:29 PM
raysadude's Avatar
yah i was relieved when i found out the problem...i was thinking i'd be screwed if the problem was with the alarm system(immobilizer) i'll check my injectors first thing in the morning thanks!
