heater control problems!! help!
Old Jun 4, 2009 | 09:45 PM
mycar2fast's Avatar
Default heater control problems!! help!
hey everyone ive been going through a long fmic d-1 install, anyway long story short after installing my gauges and jump starting my car (because i killed my batt listening to the radio.... now i can only seem to get heat out of the floor vents?!?! when i switch it tp ac or just towards the face i can still hear it blowing hard but it just wont come out.... any input is much appreciated!
thanks, Blake
Old Jun 4, 2009 | 10:36 PM
ghardester's Avatar
The HVAC (heating ventalation air conditioning) control is run by some little vacuum tubes behind the dash control. Maybe you lost a connection when you installed the dash gauges. It would make a sucking or blowing sound. Put your head under the passenger side dash and listen while you change the control from heat to vent etc. If that is the problem you should be able the hear it. You should hear the vacuum engage and stop, if you continue to hear a vacuum noise that could be the problem
If that it what you think the problem is you can pop the bezel trim around the radio and heater controls off, remove a couple of screws, and pull the HVAC control out a little and check it.
Old Jun 9, 2009 | 09:40 AM
mycar2fast's Avatar
Still having this issue !! Anyone else ??
Thanks , Blake
Old Jun 12, 2009 | 05:31 AM
mycar2fast's Avatar
I did use a long screwdriver to feed by vaccum line for the boost gauge up the drivers side behind the fuse box , Is it possible I hit something back there ??
Old Jun 16, 2009 | 09:24 PM
The Fugitive's Avatar
yeh same problem here, I will check for the vacuum noise now
