How to install Clear corner lights
Hey i just bought some clear corners for my 2000 z28 and i cant seem to pop my old ones out of place,are you supposed to get them from the bottom of the car?or what? thanks!
Now, do you mean the side lights? They should have a torx screw holding them in. You remove the screw and pull the end with the screw out first. The front of the light is a tab that holds it in.
if they are the front ones you need to do it from under the car and you need to remove the black plastic from under the car and you then will be able to access the turn signal housing its pretty much unbolt the old one and bolt in the new 1 it is a little weird pulling the turn signal housing out but just work at it and it will come out
