Please identify this device...
Old Jul 23, 2009 | 08:43 PM
38 Streetrod's Avatar
Default Please identify this device...
Can anyone out there tell me what this device is called?
Referring to the item in the photo with the blue and red connector...and it says Delphi on it... It looks like it had a fuel return line connected to it.
The motor is an LS1 from a 1998 T/A.
Someone said it might be a fuel pressure regulator, but I thought that was the metal can between the fuel rails.
Thanks!
Old Jul 23, 2009 | 08:47 PM
RA032926's Avatar
evap purge valve... it just vents fuel vapors back to the tank... i had a hellacious ticking noise and it ended up being this valve... i replaced it and the ticking is gone... guy at the dealer said they replace those all the time so i guess it's a common problem... our fuel pressure regulators are in the tank
Old Jul 23, 2009 | 08:50 PM
Nauty99SS's Avatar
^^ is correct ... and will through codes if not reconnected after intake install ...lol
Old Jul 23, 2009 | 09:34 PM
Thank you!
