Wheel size question
Old Aug 10, 2009 | 04:10 PM
marthyh's Avatar
Default Wheel size question
At a sponsor site I found a set of interesting wheels to put on my 1998 Z28 only the diametres are different .
"FITMENT: Fits stock 4th generation Camaros 1993 - 2002 and stock Firebird & 4th generation Trans Am - 1993 - 2002
MAKE: Corvette
PRODUCT: Z07 Style Deep Dish
FRONT WHEEL SIZE: 17x9.5
FRONT WHEEL OFFSET: 54mm
REAR WHEEL SIZE: 18x10.5
REAR WHEEL OFFSET: 56mm
BOLT PATTERN: 5-120.65 "
Altought advertised as fits fine,I have some questions/doubts:
1 With different wheel diameters will ABS become inop?
Or can I compensate by using different tiresize height so that circumference stays the same for e-circuits( etc.see Q4 pse.)
2.How will different wheel sizes affect driving,behaviour of the vehicule.
3 Do I need to do BFH mod for 18x10,5 in the rear.
4 Anyone advice which size tires for these wheels?
In other words go or no go ?
Thanks and Greetz from Amsterdam,Holland.
Old Aug 10, 2009 | 04:22 PM
Unertl42's Avatar
1. No, you'll use different tire heights
2. just get tires that are the same diameter and you'll have no problems
3. No, just get a 1/8"-1/4" spacer for the rear if they rub
4. 275/45/17 and 295/40/18
Old Aug 10, 2009 | 11:11 PM
Revo1's Avatar
Spacers. Done deal.
As far as I know, as long as you stay within the 18" parameter, you shouldn't need any adjustments to your fuel/braking systems, and shouldn't have to worry about rub. I have 18" Z06s on mine, AND a body kit, and my ground clearance is very close to stock. Not that I DO, but I can cozy up to most curbs/parking blocks without rubbing a bit.
