cleaning heads
Old Aug 14, 2009 | 12:51 AM
APG12's Avatar
Default cleaning heads
What should i use to clean up/degrease a set of heads. They're obviously not on the car...... just sitting all dirty in a box
Old Aug 14, 2009 | 12:55 AM
TAtoad's Avatar
easy off stove cleaner, the yellow can. and a brush
Old Aug 14, 2009 | 01:04 AM
APG12's Avatar
can i use a wire brush or should i use nylon?
Old Aug 14, 2009 | 07:28 AM
conan's Avatar
Nylon, Some thing like you would have at a kitchen sink. A wire brush will scratch the aluminum. Also brake cleaner or carb cleaner works well too.
Old Aug 14, 2009 | 07:42 AM
BlackScreaminMachine's Avatar
Internet Mechanic
For the mating surface of the head, that meets the engine block do this.
1) Scrape off any gasket, use a tool appropriate for Aluminum
2) Obtain a can of....
- WD-40
- Brake Clean (Cleen)
- Shop Rags
- Scotchbrite pads (you can use green or red, I have used both)
Do you basic cleaning by getting the heavy stuff, then brake cleen, wipe.
Then cut the pad in half, wet the pad and spray the head and start scrubbing. The WD-40 will get the carbon and other nasty stuff but not scuff the head or taking metal off the head or messing up the machining surface.
After clean up using the rag and some brake clean. Should look mint.
Old Aug 14, 2009 | 12:24 PM
APG12's Avatar
Thanks for the replies guys sounds like that should do it!
Old Aug 18, 2009 | 09:45 PM
BAD2000TA's Avatar
I used carb cleaner and a nylon brush. Just a little elbow grease and they'll look brand new.
Old Aug 20, 2009 | 12:46 AM
SchuttsR1's Avatar
I use mineral spirits. Works great.
