ported maf ends
Old Dec 1, 2003 | 12:05 PM
onebadz's Avatar
The reason your tranny will shift a little more sloppy when tempering with the MAF is because engine load is determined by MAF and the shifting is based upon engine load.
WeS
Old Dec 1, 2003 | 12:06 PM
Angus's Avatar
I just don't see how your mass air is going to make the computer adjust any tranny issues. I could probably go with a bigger mass air and throttle body because my car has a GM crate LS6 engine in it which on the ZO6 they come with bigger mass airs and throttle bodies. So I am cheating my motor of air right now. Also on the old 5.0's I have owned with an AOD I had the bullet mass air and BBK throttle body on them and never had an issue. I would like someone to explain this isse that is trained on the matter.
Old Dec 1, 2003 | 02:01 PM
unit213's Avatar
Administrator
I have a good understanding of how the MAF and tranny line pressure are related. I could tell you what I know about it, but it sounds like you're looking for someone who has extensive info on the subject. I think Colonel is the most educated in that area.
Old Dec 1, 2003 | 03:21 PM
onebadz's Avatar
Angus check this out, all the info you will ever want on the GENIII motor's MAF, select the MAF thingy from the left hand side selection chart http://carprogrammer.com/Z28/PCM/LS1/Holden_LS1.pdf
WeS
