Ls2 intake ?
here is the ls2 intake http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
is it so short in the front cause of comletely deleting the egr mold and using drive by wire tb?
Or do i just need a newer ls6 intake and all my **** will bolt on it?
Here http://cgi.ebay.com/ebaymotors/2001-...item53d3d655fe
in other words one is longer than the other to accomidate different tbs?
If you do use the ls2 you will need different O rings for the injectors. You will need to shim the fuel rail where it bolts to the manifold. Also need a 90mm TB and extend the map sensor. Im pretty sure you are going to need an ls2 fuel rail too
If you were going to buy the ls6 intake off ebay for 345, would you guy this instead?
http://cgi.ebay.com/ebaymotors/LS1-I...Q5fAccessories
flow through rails and comes with a bigger tb, but will it flow the same as an ls6 intake?
tia
