Rebuild Engine or Replace???
Old Dec 15, 2009 | 06:59 PM
BKC2006's Avatar
Default Rebuild Engine or Replace???
I just purchased a 2000 Camaro SS. It has stock LS1 motor with T-56. Im familiar with these cars I have owned 3 LS1 Cars and 2 LT1 Cars. The motor in the car I just bought is Knocking in the bottom end and has no oil pressure. This car is gonna be my daily driver. Should I rebuild it and stroke it or should I buy a used engine and slap a small cam in it. I just want to be able to drive it anywhere with a little more Horse Power then stock. I talked to a local shop and they told me to buy the used engine and put a small cam in it and have the stock heads ported and polished. I need some other opions please help!! thanks
Old Dec 15, 2009 | 07:14 PM
SOMbitch's Avatar
Your budget will decide this. How much coin you wanna drop?????
Old Dec 15, 2009 | 07:32 PM
NAAllTheWay's Avatar
well if you know anything about skateboards...your question is the equivelant to asking whats better? a zero or a birdhouse?.....get what i mean?...both great options, i dont think ones better than the other, just depends what you want to do. thats just my opinion.
Old Dec 15, 2009 | 10:14 PM
araber89's Avatar
From: Holmes County (thats right Amish Country), OHIO
What The F*** did I just read...
Old Dec 15, 2009 | 10:25 PM
pheer's Avatar
...zero, duh
(Zero is a skateboard equipment brand, birdhouse i believe is Tony Hawk's Brand?)
Old Dec 16, 2009 | 08:47 PM
BKC2006's Avatar
I wanna spend about 4000 but keep it a daily driver. I was quoted 2 grand for a motor with 70k and 2300 to have stock heads ported and a trick flow cam 222-224 lift new oil pump,timing chain,gaskets,pushrods..is that a fair price?
Old Dec 16, 2009 | 10:52 PM
bderlan's Avatar
2300 for just those parts and the head porting? if thts so y dont u check texas-speed.
Old Dec 18, 2009 | 11:32 AM
bgoodeno's Avatar
For a true DD I'd slap in a used motor and save a build for a toy. But it sounds like this DD is gonna be both... therefore i'd rebuild and stroke it with a new rotating assembly. the top end could be enhanced later.
Old Dec 18, 2009 | 12:00 PM
Ke^in's Avatar
Seen those trick flow twisted wedge heads tey have for LS1 engines? They are BAD-ASSED.
Old Dec 18, 2009 | 01:58 PM
Juicy J's Avatar
Jesus man, do you work for Trick Flow's advertising department or what? I think 95% of your posts are about Twisted Wedge heads.
