what does this mean?
Old Dec 22, 2009 | 04:09 PM
00TAM6's Avatar
Default what does this mean?
i get in my car. step on my clutch. turn the ignition and it doesnt start. its like im trying to turn on the car without stepping on the clutch. sometimes i release the clutch then step on it again and it starts. can that be my starter?
Old Dec 22, 2009 | 04:11 PM
2001slppewterss's Avatar
I think there is a safety switch or something that is engaged when you push the clutch in....that must be going bad on your car.....I'm sure someone else that knows for sure will respond shortly....
Old Dec 22, 2009 | 04:14 PM
I think it's called "neutral safety switch"
Old Dec 22, 2009 | 04:22 PM
TheBlueKnight's Avatar
Yup, there is a switch down by the clutch pedal. It engages when you press in the clutch pedal and lets the engine start. I'd crawl under the dash with a flash light, find the switch, and see what's going on down there. May not be a bad switch, maybe the pedal is not pressing on the switch right or something.
Old Dec 22, 2009 | 04:54 PM
00TAM6's Avatar
thanks. i forgot to say that when that problem does happen there is a click everytime i try to start it( 1 click per turn) idk if that changes things but lmk. thanks
