How to do a BFH mod?
for not being scared to ask...some people would of probably flamed ya for not knowing.honestly it is quite a bit of clearance what tires are you planning on running?
offset LCA's (lower control arms) help quite a bit too.
Chad
this would require adj panhard rod bar (to center the rear), offset LCA's, cutting the rear bump stops, and of course the BFH mod
here is a thread showing how close your getting...this car has a 11" narrowed rear however (not required)
https://ls1tech.com/forums/drag-raci...er-15x12s.html
here is my car on the 325's, moser 9" stock length, adj PHB, offset LCA's, BFH, rolled fenders (not required but recommend it), cut bump stops, had to grind the stock rear brakes to fit the 15's as well.
hope that helped!
Chad
Chad
