help-A-noob (what is this)
Old Jan 5, 2010 | 11:09 PM
mike1stcamv6's Avatar
Default help-A-noob (what is this)
hey guys i have seen some ls1's with and wothout this
i would guess its a upgraded or updated part for the newer ls1s maybe 1999-2002? mine has a reguler hose and i want to know if i shoud get one of these or what are the benefits if any thanks
Old Jan 5, 2010 | 11:13 PM
Breathing Fire's Avatar
It is radiator hose. Just a metal section. Kinda held in place by that plastic clip. Its normal.
Old Jan 5, 2010 | 11:23 PM
therealcreeper's Avatar
no. it's a power steering cooler. 98-99 WS6's and maybe SS's came with them, as did all 00-02's. might have also been an option from 98-99. it's really not beneficial. some argue it actually makes it hotter and i believe a few people have had it leak causing the power steering fluid and coolant to mix.
if you plan on road racing/autoxing you may want to look into a real cooler eventually, or just go with a reduced flow pump (i'm doing the latter)
Old Jan 5, 2010 | 11:38 PM
DrededSS's Avatar
It caused the power steering fluid and coolant to mix on my '99 WS6. I deleted it. Probably going to do the same if the one on my '00 SS ever gives me any problems.
Old Jan 6, 2010 | 12:27 AM
wow thats real useless thanks for the quick info i guess it a no-need no-go
Old Jan 6, 2010 | 08:55 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
PS cooler is RPO V12, it was standard on SS and WS6 from '98+, and did not become standard on the base V8 models until 2002.
Old Jan 6, 2010 | 10:19 AM
thatguy383's Avatar
so i most likely have this?
Old Jan 6, 2010 | 10:53 AM
Gaunt's Avatar
I have one on the Z28 >_>
Thought that was standard on all F-bodys, shows how much I know haha.
Old Jan 6, 2010 | 10:56 AM
thatguy383's Avatar
if it sucks I don't want it, wonder how i can remove it...
Old Jan 6, 2010 | 11:16 AM
RPM WS6's Avatar
My '98 doesn't have this, neither did my '99 Z28
Get a radiator hose for a '98 Z28, then delete the cooler.
Old Jan 6, 2010 | 11:31 AM
according to GMHTP they became standard in 00' but they could be wrong
Old Jan 6, 2010 | 01:17 PM
RPM WS6's Avatar
This could be correct. The more I think about it, I'm not 100% sure if it was '00, '01, or '02. But I'm certain the '98-'99 base V8s didn't have it.
Old Jan 6, 2010 | 04:20 PM
nemss1's Avatar
good info. im off to get a radiator hose for a 98. i deleted power steering anyways
Old Jan 6, 2010 | 05:59 PM
dgcustomz's Avatar
I deleted the cooler in my 99' SS and after deleting it my powersteering got harder when turning. It felt like it was tighter. I reinstalled it and got back to normal.. I don't know if my car was just being sensitive to the mod or what?
Old Jan 6, 2010 | 06:02 PM
RPM WS6's Avatar
PS feels the same in my '98 Z (without cooler) and my '02 Z (with cooler). Not sure what happened with yours?
Old Jan 9, 2010 | 12:04 AM
transam5.7lt1's Avatar
Just like everybody said, power steering cooler......many say power steering system runs hotter with it.....
