Electrical problem. Can anyone help?
1 you have a 99 car, and the cluster is going bad.
or 2, you have a battery that is not up to par.
Replace or test battery first, and if you have a 99, decide to try to get it fixed, or live with it.
Ryan
Ryan
P.S. there is a TSB about the tripmeter resetting back to 0 every time the car starts I thought that was my case but it wasn't
If this is loose or corroded it will cause the problem. Good luck
If you have a good volt meter place one lead on the ground post at the battery (not the cable but the actual battery post) and the other lead on the cable end on the frame, set the meter for dc voltage low range under 5 volts and have someone start the car, if the voltmeter shows over 1/2 volt while cranking, the ground connection on the frame or battery need's cleaning.
Good Luck
odometer reset on me, but seemed only when it got real cold. Past
couple weeks the car has been really hard to start, so I finally figured
to replace the battery. Being that I like to support those people who
are trained to do this job, I took it to a local shop, as I was in a hurry
and trying to get to a prior engagement. Got the battery replaced by
a hottie working at the shop (nothing sexier then female mechanics!
)and now I've noticed, no more trip odometer resets.
