t56 to a4
Old Jan 27, 2010 | 10:15 PM
nncfan8's Avatar
here is a good write up bro
http://www.myls1.com/cmps_index.php?...toa4conversion
Old Jan 28, 2010 | 11:53 AM
Ls1N20's Avatar
Where can i find a pnp switch
Old Jan 29, 2010 | 12:08 PM
the_merv's Avatar
On a Shifter..look in the Junk Yard.
Old Feb 5, 2010 | 04:32 PM
swomp rat's Avatar
What if I run a 700R4....? That is a non-computer controlled trans?
Old Feb 5, 2010 | 04:43 PM
gtfitter597's Avatar
I think going to an auto is stupid.....but.....If I did I would definately go with a 400. There are plenty of conversion kits. Keep it simple!
Old Feb 5, 2010 | 04:55 PM
Ls1N20's Avatar
Financially it isn't stupid. Think about it a t56 is what? 800 bucks? I got tranny and everything i needed to bolt the tranny in the car shifter, consoles EVERYTING for 400 bucks with trade of what i could give. Including trading wiring harnesses. so no. it's not very stupid.
Old Feb 6, 2010 | 12:00 AM
Frametwista's Avatar
i think manual is stupid.everybody has his own taste i hate rowing gears through traffic all the time too so keep your opinions to yourself go auto i did and i love it get u a stall an outrun them 6 speeds all day.u can just get your pcm reflashed u dont have to get another one u didnt even need a auto wiring harness i got my m6 harness on my auto 4l60e there is a company called lsx tune that makes the conversion harness to the pcm for guys wanting to go auto 99 bucks its not that hard dont let no one deter u 6 speeds sucks.
Old Feb 6, 2010 | 12:20 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Again, lets leave the auto vs manual battle out of this thread.
Also, if I see any more posts calling the OP stupid for wanting an A4, I'm just going to delete your post, so don't waste your time writing it.
Old Feb 6, 2010 | 06:58 AM
the_merv's Avatar
Then you won't need alot of the Electronics..there are a few things you will have to still wire up.
Old Feb 6, 2010 | 07:21 AM
Black FormulaLs1's Avatar
best of luck to you on your swap!! but can you pm me and tell me where the hell your getting T56's for 800$$$>>>>
Old Feb 6, 2010 | 12:36 PM
RPM WS6's Avatar
700R4 uses a T.V. cable for line pressure control (not vacuum controlled like the TH350/400), so just keep in mind you'll need to run that cable.
Then again, maybe someone makes a kit to convert a 700 to vacuum modulation?
Old Feb 6, 2010 | 02:41 PM
  #32
Ls1N20's Avatar
Well i went to a junkyard and cut off a pnp switch, now where do i splice the wires into?
Old Feb 6, 2010 | 03:07 PM
  #33
the_merv's Avatar
What did it come off of?
Old Feb 6, 2010 | 03:39 PM
  #34
Ls1N20's Avatar
lt1 car
Old Feb 6, 2010 | 04:03 PM
  #35
the_merv's Avatar
Ok..you are going to have to get a wiring diagram for it and run the wires..hopefully someone here has one..I don't cause I've never had to do it.
Old Feb 6, 2010 | 04:36 PM
  #36
Ls1N20's Avatar
Gah momma ceta
Old Feb 6, 2010 | 04:40 PM
  #37
the_merv's Avatar
Que..?
Old Feb 6, 2010 | 04:41 PM
  #38
Ls1N20's Avatar
Just ths wiring is getting to me hahah Once i get the wiring done i should be able to bolt everything in and start it. I never heard anything about not using the pnp Can i skip it?
Old Feb 6, 2010 | 04:56 PM
  #39
the_merv's Avatar
Not really..
Old Feb 6, 2010 | 05:09 PM
  #40
Ls1N20's Avatar
why? What makes this damn thing so freakin important
