e-cut out help,
Old Feb 8, 2010 | 06:19 PM
cheeseLS2's Avatar
Default e-cut out help,
im trying to install my electric cut out qtp e cut out.
im trying to find a way to run the wires into the inside of my car but dont know how or where to start,
any help would be ok,
Old Feb 8, 2010 | 06:31 PM
Greekey's Avatar
Where are you putting the cutout? If its under the rear passenger seat like most people do, there is a rubber grommet right underneath the rear passenger seat underneath the carpet.
Old Feb 8, 2010 | 06:45 PM
cheeseLS2's Avatar
yea underneath the passenger side on I part of my y pipe
and im going to splice the wires from my cig lighter to make the switch work,
Old Feb 8, 2010 | 06:54 PM
Greekey's Avatar
Where are you mounting your switch? Heres mine:
Old Feb 8, 2010 | 06:56 PM
cheeseLS2's Avatar
i was thinking of putting it in my center counsel ash tray.
wow that looks very flush and factory
Old Feb 8, 2010 | 06:59 PM
Greekey's Avatar
It was a pain in the *** mounting that switch there. Had to remove the drivers seat to bring the wires right underneath it. Had to drill a hole to make the switch fit. I tapped into the seat controls for the electrical.
Greekey's Avatar
First cutout?
Old Feb 8, 2010 | 07:12 PM
Greekey's Avatar
Follow this link. At the top right hand corner you will see the rubber grommet. https://ls1tech.com/forums/album.php...pictureid=9215
Old Feb 8, 2010 | 07:30 PM
Ran-Dom32's Avatar
[QUOTE=cheeseLS2;12865951]i was thinking of putting it in my center counsel ash tray.
don't use the cig. lighter for power
that will run the battery down, you need a power source the turns on with the key, I found an empty fuse block , ran a wire w/fuse to the ash tray, underneath the car I put a x in the rubber grommit & ran the cutout harness under the carpet & came out under the center console, the switch fits perfectly in the ashtray
Old Feb 8, 2010 | 08:23 PM
cheeseLS2's Avatar
Ok i thought the cig lighter was a good idea, does the seat mounting drain the battery? Since u can adjust the seat with out the car having to be on?
Old Feb 8, 2010 | 10:35 PM
PIZDETS's Avatar
Mine does not, if you have a LED it might.
Old Feb 8, 2010 | 10:48 PM
Greekey's Avatar
It wont drain the battery. The only way it will drain the battery is if you open/close your cutout with the car off. You don't need a switched 12-volt source.
Old Feb 9, 2010 | 08:10 AM
Ran-Dom32's Avatar
my qtp cutout came with a led lit switch which stays on all the time if hooked up to a live wire, that's why I hooked it up to a switched ignition wire, (will not be an issue if you have a switch w/o the light in it)
