LS1 Crank in LS2?
If i remember correctly the 06 LS2 gto's use the newer relucter wheel setup, where as if it were a 05 LS2 gto it would use the older (ls1) style relucter wheel. So no, I do not believe you can use a 06+ LS2 crank in an older LS1 engine. (unless you changed over the cam/crank sensors/ecu etc...)
sorry, I just reread it, take what I said and reverse it. You need a crank from an 06 and newer LS2. The relucter wheel on the crank for the crank sensor is why you can not.
