ls1 intake on 5.3
I just did this.
You will need the car fuel rails, car injector, change the injector plugs to EV1 style (if you're using a truck harness)
you may need to modify/change your steam vent depending on the year of your 5.3,
you will need to change to car accessories or change water pump pully and move/modify the outlet, and reroute the PCV system.
You may also need the intake bolts that go with the LS1/6 intake.
Also, be sure to either modify the clips on your MAP sensor because the truck one attaches differently or buy a cap MAP sensor.
