Oil Pressure Issue?
1) 60psi under what condition....Cold idle? Warm idle?
2) Looking at your dyno numbers, the car is clearly modded and likely has a cam. There's a chance that the oil pump was replaced with a modded pump at that time which would normally show higher pressure than stock.
2. It does have a small cam, with ARE oil pump. So this is normal with an aftermarker oil pump? Thanks for the help.
