Got some problems PLEASE HELP
im at work today and im talking to one of the guys who works there just at night a couple times a week. his other job is he works for a pontiac dealership as a mechanic.. so we where talking about my car and somehow a coolant question came up.. he is like ur running dexcool right? i was like no the guy at my dads body shop said it was fine to run this other stuff. (keep in mind my car was a salvage title and we put a new radiator in it as one of the repairs) so then i put in a 160 degree stat.. so i told him about the stat and not running dexcool.. and he was like ur nuts for not running the dexcool.. and the car is probally runing worse with the 160 stat.. he said to put the stock thermostat back in and change to dexcool cool... but here inplays the problem.. i figured tommorw i will flush my coolant system and add dexcool. (he said running the green stuff for a little while wont do any damage) but he siad he wanted me to flush my system real good, let the water from the hose run through the engine for a while, but then he said it may not be good because it is cold out and if some water stays in the engine and freezes it will crack the block?
the guy from the dealership said i had to do all this confusing **** to flush my coolant, it went like this 1. open the coct from the bottom of the rad and let all the coolant drain. 2. take the bottom hose of the rad, then take the thermostat out, then put the hose in the thermostat area and let the water run through for a while. he was also saying try to get some heater core lines of and stuff like that.. it went on and on about stuff i had to remove and run water through..
the guy from my dads shop said that i should just drain the rad then put the hose in the top of the rad fill it with water and let the car run with the coct open on the bottom of the radiator, therefore the water will cycle through the engine and remove all of the coolant ( when i first got the car we flushed it like this).
the question im asking u guys is WHAT TO DO?
my options are
1. leave everything like it right now until it gets warm
2. flush the damn coolant the mad confusing way and add dexcool
3. flush it the way the guy from my dads shop said i can do it and then add dexcool.
4. should i keep the thermostat in or put the stock one back on?
please guys help me out here... if u can ill be online for the next few hours.. reply or hit me up on aim the sn is bodyblaste
Wes
