LSX parts interchangeability
I'm currently buying up parts for an lq9 based 408. From what i understand, you can pretty much use any lsx part with these blocks. Is this true?
for instance can i use an ls1 cam, ls6 heads, and ls1 sensors?
Yep. All that will move over to the new block. If you are putting it in with F-body accessories, you will need to drill and tap one hole for the alternator. Other than that, it will go right in!
Jon
Jon
thanks for the help.
the only other question i have pertain to electronics. Im going with a 24 tooth crank reluctor wheel and im curious as to what sensors i can/should use. Can i use ls1 sensors for the motor if im using a stand alone ecu? or will i have to go to the junk yard and find a 6 liter vortec motor and grab the sensors?
