Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Transmission Guides
- Camaro How to Change Rear Differential Fluid<br>Step by step instructions for do-it-yourself repairs.
Rear Differential Fluid Change Interval
I asked a Chevrolet dealership mechanic that I know, he has been with GM for 18 years. He said he has never seen a rear differential go bad because the fluid had not been changed. He said the only reason they go is if they leak and get low on the fluid, or the F body is modded to the point it overpowers the rear diff, and then the owner should upgrade anyways. But he said he has never seen a case where "old fluid" caused any type of failure or even wear on the parts inside the differential.
Now he did say if he had a lot of money invested in a car and was racing it all the time, he would be like you guys and change it every 10k or so, just so that he could look for wear on the parts inside than for the sake of changing the fluid.
He did say make absolutely sure you use the GM additive, if you don't the rear diff will fail.
Originally Posted by Mike02Z
My question is how much oil does the rear diff and manual gearbox hold in an 02? I'm planning on replacing both at my next oil change as the car has 22k and I have no idea if it was ever changed before I purchased it.
-Mike-
-Mike-
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
-Mike-
-Mike-
Bill
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
![Angry](https://ls1tech.com/forums/images/icons/icon8.gif)
Originally Posted by ULTIMATEORANGESS
im curious why the factory cover has a magnet and aftermarket girdles dont.at least my mac doesnt.
Bill
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by sscamaro02
The reason there isn't a drain plug in the rear,is it don't have to be changed.I have been driving for 53 years and have never changed rear end fluid. I have never had a problem either. The same goes for the stick trans.
car-modders are a different story. you are probably more likely to hear noise in either the trans or the rear diff much more often than a near-stock car.
once again, another nice thing about keeping your car mostly stock
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
