1998 vats
1998 vats
I am pretty sure that is why the car is limp and the starter wont crank. I have already taken it out and checked it. Checked all the fuses and relays and everything is good. How do I disable the VATS? I have read I need to measure the resistance in the pellet on my key and instal a resistor? has anyone on here done this before? Any pointers? Do I need the key in the car with power going to the ignition to perform the test? I am lost on how to do this.
Yeah you do need to measure the resistance of the VATS system. Here are a couple of good links to follow.
http://www.shbox.com/1/pass_key.html
http://www.shbox.com/1/air_bag_disc_2.jpg
Using a resistor to bypass the system works well. will cost you only a couple of bucks if you have a multimeter to mesure the resistance. The resistors are about 50 cents for a 5 pack from radioshack.
Also if you have an ACE hardware close to you, they can make copies of the chipped keys, and they have a machine that mesures the resistance of the key, so they can tell you what pellet count you have.
If I remember correctly you splice the wires into the vats side of the connector. So cut the two wires and splice the resistors into the two wires on the vats side and just leave the connector laying there. Basically what you are doing is just bypassing the keys resistance. When the vats system sends out a signal looking for the correct resistance to come back to it, instead of the signal running up the steering colum to the key cylinder and meeting the resistance there, the resistors bypass the key cylinder. If you have any other questions PM me.
