will this fit?
Old Aug 9, 2010 | 08:30 PM
ToxicWS6's Avatar
Default will this fit?
was lookin at upgrading to an ls6 intake manifold for my ls1 and i was lookin at getting this 92mm TB and it says it will fit FAST 92mm manifold ls3 intakes and "others" will a ls6 intake manifold be considered "others" dont wanna get it if it wont fit
this is the TB i was lookin at gettin
http://texas-speed.com/shop/item.asp?itemid=1093
Old Aug 9, 2010 | 08:48 PM
SOMbitch's Avatar
No it will not fit. You should port and polish a stocker........ If you don't do it youself a P&P job should be in the $60 range......
Old Aug 9, 2010 | 09:37 PM
FireTA98's Avatar
^^^^x1 Registered User
^^^^x1.
Old Aug 10, 2010 | 09:32 AM
ToxicWS6's Avatar
ight, for P&P of the TB i know u just get a fined grited dremel and just make the inlet bigger and all is there anyway u could **** these up easy or not really? and is there a wrong way to do it that u lose power? might try myself
Old Aug 11, 2010 | 06:19 PM
SOMbitch's Avatar
If you search external there are many pics and IIRC a how to thread. I have also seen a "how too" vid somewhere maybe youtube.....
Old Aug 12, 2010 | 09:44 AM
Jon@Texas-Speed's Avatar
You do NOT port the area around the blade. If you open it up and it doesn't seal correctly, then you just ruined a TB. Basically you are trying to smooth the area where the air is coming into the TB. Not actually making it bigger.
Jon
Old Aug 12, 2010 | 01:06 PM
ToxicWS6's Avatar
i was doin some research on it last night and all, do i have to remove the butterfly flap or is it just a good idea? and if u use a dremel and ether a sander bit or something how quick can it or will it eat it away? i wanna do it my self but dont wanna mess my tb up, is it just a take ur time and ur fine or is it real touchy, like soft metal?
Old Aug 12, 2010 | 01:50 PM
WSsick's Avatar
I havent done it myself, but with everything you should take your time. People do it all the time around here themselves for a free mod, some see gains, others just report better throttle response. ive never seen data on it back to back. If you are worried about messing it up, there are 2 options:
1-find a write up (theres 1 for almsot anything on this site if you serach good enough)
2- pay for it ($50 is the norm here, good hp/$)
