Dummy Coolant Gauge?
Old Sep 25, 2010 | 11:56 AM
tmdz28's Avatar
Default Dummy Coolant Gauge?
I have heard that 99+ camaro are equipped with a dummy coolant gauge?
Does this mean, that the "dummy" gauge show a consistent temp unless you're severely overheating?
Old Sep 25, 2010 | 12:04 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Basically, yes.
The '99+ gage will show right about 210° any time that coolant temps are in the 185-190ish to 230-235ish degree range.
Old Sep 25, 2010 | 12:21 PM
tmdz28's Avatar
Originally Posted by RPM WS6
Basically, yes.
Ahh, thanks.
So basically the same gauge that 99% of cars on the road have.
Old Sep 25, 2010 | 12:52 PM
01ssreda4's Avatar
Yes.....
Old Sep 26, 2010 | 12:05 AM
myk's Avatar
myk
So....if you're starting to overheat the gauge will let you know...somehow, someway...right?
Old Sep 26, 2010 | 12:31 AM
burtonboy's Avatar
yea it will let you know if your starting to over heat. I'm not sure at what temp it starts to change but it def does at some point.
Old Sep 26, 2010 | 05:40 AM
transamtom's Avatar
Your check gauges light will also come on if it gets too hot.
Old Sep 26, 2010 | 03:00 PM
nolo200's Avatar
Yes. Not a very good indicator if you know what you're looking for. upgrade.
Old Sep 26, 2010 | 06:16 PM
ToxicWS6's Avatar
i have a 2000 ws6 and my temp gauge seems to be pretty on point, havnt put it to a test but before the 160 degree thermostat it sat at 210 but if i ran hard it would go up maybe 5 degrees then drop down, and now with the new thermostat i run at about 175-180 degrees, i feel mines basically accurate but
Old Sep 26, 2010 | 06:27 PM
Mumbles's Avatar
Anybody have any recommendations on what type of gauge (Brand Name?) as an upgrade to have a more accurate Temp Reading?
Old Oct 5, 2010 | 06:29 PM
HotSilverBird's Avatar
Its not a dumby gauge by any means, it is setup like your fuel gauge. It shows a average instead of a instant so people don't complain about the temp gauge swinging high and low. SO this means its dead on but shows you an average. If you are running 180 average that what you will see real time. If you run hotter it will show hotter but not instantly, as the average temp increases so will the temp gauge. It works exactly like your fuel gauge, think of it like that.
GM did this because so many people complained about the temp gauges swinging over a wide range.
I think it works very well, it averages quickly so there really insn't anything to worry about. If you are running hot or cold it will show it.
Old Oct 5, 2010 | 06:33 PM
Basically, yes.
Not true, it shows the average of what you are. so you don't see the spikes. If it stays at 230 it will show 230.
Old Oct 5, 2010 | 09:19 PM
RPM WS6's Avatar
Watch the real temp with a scanner. It can stay within 20 degrees of the gage temp shown forever and the needle won't move.
I spent hours tuning my '00 car, looking at tons of logs. Coolant temp could be at 190°F for an entire highway log, and the gage would still show 210°. I'd say there is a buffer built in, not an average.
Old Oct 5, 2010 | 10:35 PM
94 Camaro Z28's Avatar
So did '98 cars have a gauge that shifted as opposed to a dummy gauge?
Old Oct 5, 2010 | 10:38 PM
RPM WS6's Avatar
Yes, the '98 gage shows more minor changes in temp.
Old Oct 6, 2010 | 03:02 AM
Quite honestly i'm not sure why none of the guys that does programing hasn't changed the values in the PCM programing to have the 99 up cars update the temp real time. It should be easy, everything is there just like the older cars just that the info sent out of the PCM on the serial buss to the temp gauge has been averaged.
Old Oct 6, 2010 | 10:10 PM
SOMbitch's Avatar
Not sure if this is right....I thought the 98 temp guage had an extra wire on it which helped with real time reading.... I just remember when I ordered my 98 CTS it was year specific because it had an extra wire.... Correct me if I am wrong because it was 3 +years ago....
Old Oct 7, 2010 | 01:16 AM
RPM WS6's Avatar
You are correct, the '98 sending unit is a 3-wire vs a 2-wire for the '99+.
Old Oct 7, 2010 | 06:54 AM
Tobias05's Avatar
here you go electrical engineers:
make your coolant temp gauge work
Old Oct 7, 2010 | 12:26 PM
RPM WS6's Avatar
Just to reconfirm, it's definitely NOT an average. I did some cold start scanning on my '02 car, and the gage was already showing just a hair under 210 when coolant temp had only reached 188°F during that key cycle.
