heads??
Old Oct 7, 2010 | 01:38 PM
dont z20h8's Avatar
Question heads??
how can i tell which kind of head i have?
ok EDIT: i went outside and looked but was not able to locate the head casting number and i didnt even smoke a joint today
Old Oct 7, 2010 | 01:50 PM
Jon@Texas-Speed's Avatar
There is a casting number on the top corner of the heads. Should be 3 digits. 706, 862, 853, 241, 243, 799, 823, etc.
Jon
Old Oct 7, 2010 | 02:52 PM
garygnu's Avatar
on the right side of the motor where the heads meets the block,the lower right side of the head next to the exhaust manifold there be a 3 digit number.what yr is the car?
Old Oct 7, 2010 | 03:00 PM
dont z20h8's Avatar
its a 98 z28 ,, ihave the 806 heads i had to take a shirt n sum water to see thanks
Old Oct 7, 2010 | 03:16 PM
Yeah those are stock '98 perimeter bolts heads.
Jon
Old Oct 7, 2010 | 03:26 PM
dont z20h8's Avatar
Jon
not worth a lick of hp?
Old Oct 7, 2010 | 03:30 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
They can look externally stock and still be modded, if that's what you're asking.
All the stock LS1 heads (806, 853, 241) can make equal power with the same port and valve modifications. Most agree that 241s flow a tiny bit better in 100% stock format though, due to the casting proceedure.
Old Oct 7, 2010 | 03:47 PM
WS6SP33D's Avatar
So whats the big differences? mine are 853's
Old Oct 7, 2010 | 04:50 PM
z28camaro1090's Avatar
there really isnt a big difference once they are ported. The 241's stock flow alittle better
Old Oct 7, 2010 | 05:15 PM
RPM WS6's Avatar
806 use perimeter bolt valve covers and individual ignition coil attachment.
853 use center bolt valve covers and an ignition coil rail that bolts all the coils to the valve cover as a single unit.
241 are the same as 853s but were produced using a slightly better casting method that results in ever-so-slightly better port walls than the previous heads.
They all have the same potential.
Old Oct 7, 2010 | 05:22 PM
WS6SP33D's Avatar
Thanks for the info, good to know
Old Oct 7, 2010 | 06:27 PM
dont z20h8's Avatar
closed mouth never gets fed sheesh i learn something new about a ls every day i love it lol
