Help with a starting point
So I need some direction. I thought about a truck motor to keep costs down, but I really don't want the weight of the iron block. I'm looking for what castings/years/etc might be the best mix n match to get me in the ballpark. I could just buy an LS7, but I'm not made of money
Target HP is 500+
Pump gas only
most likely T56 behind it
If you were building a "budget" 500 hp LS, what block, crank, heads, intake etc would you use?
Jon
I'm spending the biggest part of my wad on a gmachinechassis.com frame or something very similar.Target weight for the car is mid to high 2000s with driver so cubes are a concern, but anything in the 350+ cube range should suffice.
Basically first gear final drive target ratio will be in the neighborhood of 11:1 so with a 24-27" tire size that should cover most cam choices in the 550hp range and final ratios and tire sizes can be tweaked from there.
