L92 swap to 02 Z
L92 swap to 02 Z
2010 6.2L. I read stickies on how to convert it over but wud it be beneficial to jus find a 6.OL out a gto and wrk it wit L92 heads and cam.....which wud be easiest and best?
Well unless you get an early LS2 motor you will still need a box to convert the 58x reluctor signal so that is a wash. You need extensions for the crank position sensor and knock sensors either way so not much much difference there. You would need to make sure the l92 came complete with the intake or buy one. You also need to fab a mount to convert the l92 from DBW to cable operated TB.... Not really familiar with the l92/ls3 transplant but this is what immediately comes to mind...
