header /egr gasket for header install!
Ok guys I had a header install done to my 02 camaro SS! I used the gaskets ygat came with the Headers like an idiot! I just called the GM dealership that's close to my house to order OEM gaskets! My install guy said I need the header gaskets of course! And 3 egr gaskets! Now the egr gaskets I am not sure the name/or part number! And that's what I need so I can order them! He said its where the injector conects to the manifold!that I need the gasket for that! He said its like 2 or 3 bucks each? Any one know what that gasket is called or even the GM part number!
You could use grafoil Gasket material you can get it in rolls just get it about 1&1/2" to 2" wide and use the flange as a template and cut about 3 Gaskets for each flange and I applied muffler patching compound onto the gasket material to help seal mine when I deleted the EGR system. The grafoil tape is just graphite tape and makes a high temp seal when compressed between the two-bolt flanges.
