Looking for a "start up guide" after rebuild.
Does anybody have a link(or book) that can guide me through starting up a LS1 motor after a rebuild. I've build and started many "non LS" motors, but I've already found that there's lots of good details to know about each(ie - the oil plugs, priming the motor, etc.). Any advice here would be great. Thanks!
https://ls1tech.com/forums/generatio...rocedures.html
Refer to post #10, I trust this guy all day long
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
I usually do the same thing only leave the spark plugs out too, may not make any difference but I figure it cant hurt to take a little extra load off the rod bearings, plus it turns over faster/builds oil pressure sooner. Kent Moore has a special tool that I use at the dealership that taps into an oil gallery plug and pumps oil into the oil gallery. It's not totally necessary, but If your that worried about it I suppose a crafty fellow could build a tool that did the same thing.
The only thing I would change in Damiens post is to use an oil like a Joe Gibbs or Comp Break In Oil that contains a lot of ZDPP. The roller cams in these motors don't need it like a flat tappet cam but it still helps the rings to seat...... Not totally necessary but still a good idea....
