Speedometer and tachometer
Old Dec 22, 2010 | 08:00 PM
M1T/A's Avatar
Default Speedometer and tachometer
Hey guys I put a new engine in my 99 T/A about 20 miles ago and all the gauges were working fine. Now all the gauges just went haywire bouncing back and forth (on my way home) for a few hundred feet. They all went back to normall except the tachometer and the speedometer, which completely stopped working. Does anyone have a clue as to what may have caused this to happen?
Old Dec 23, 2010 | 02:19 AM
Finkledbody's Avatar
Not sure about them not working but the speedo bouncing around has happend in both my f-bodys. Sometimes it turned out to be loose positive/negative connections to the battery. Others times they have just been corroded and in need of being cleaned up. I'm sure your problem is a lot worse though. Good luck to you though.
Old Dec 23, 2010 | 09:54 PM
M1T/A's Avatar
Ya i searched before posting and found several guys that had the same problem as you, and i checked the battery terminals (took them off and put them back on) and all seemed good. Thanks man
