need help figure two things out
I changed my original MAF with Z06 85mm maf since then I've been having P0102B MAF sensor circuit low freq thrown, I googled but couldn't find any relevant info what could cause it, either dirty maf or broken maf..
Second question, around 1k miles after last oil change, my oil change light would stay on for around 30 second and then gone, I've no idea what's going on
The car runs, idle fine. Not a single problem under WOT whatsoever..
Any help would be appreciated, I'm dumbfounded here
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
A tuner needs to calibrate the maf tables in your PCM to accomadate your new maf. Put your old one back in until you do this.
You didn't rest your oil life monitor when you changed the oil did you?? Turn the key forward (but don't start the car) and depress the gas pedal all the way down 3 times in a row to reset it. The message center will blink to let you know you have reset it.
