IAC problem
IAC problem
I have been having idle and starting issues, ever since i got my mods done (243s, Fast Intake, 92mm tb). All vacuum issues have been addressed so I was going to check/ clean the IAC. Well it turns out the top screw is stripped pretty bad, any ideas on how to get it out?
I assume your talking about the 2 screws that hold the IAC in the tb?
Needlenose vise grips, were u using a torx bit? Sometimes between a torx/allen head you can find a size that's snug enough and with firm pressure crack it loose. I would take the tb off so i could get a good angle at the bolt.
