ms4 cam install
i have a ls6 out of a 04 zo6 and putting it into a 92 z28 convertible and getting ready to order a ms4 cam,springs and push rods the engine is all stock with 20k on it will i need to do anything to the engine like flycutting the pistons i know it will be close but i just wanted to see what everyone else has done and what lsa do you think i should get it is not going to be a dd just onec a week i just want it to sound good thanks
You shouldn't have any PTV issues with that cam on factory heads. Like with ANY cam, check PTV before you fire it up. I would tell you to do that on a 220R cam as well. Everyone makes mistakes and it is easier to fix before you bend all the valves. (knocking on wood of you!) I would recommend a pump and chain while you are in the motor but it isn't a must. Same goes with the trunion upgrade kit. It is nice to have in there but not a must. Stock rockers work fine on that cam but every now and then they kick the needle bearings out. I have seen them do the same on a stock cam as well. Just double check everything and take your time and you should be good!
Jon
Jon
