RPO help can't find these in the sticky
so i read the sticky for RPO's i wrote everything down off of my RPO sticker in the door and i still have quite a few that i havent found if anyone knows what they are please let me know... 1SD,1SZ,19I,SLM,STE,192,6BS,7BS,8TJ,9TJ.
this is printed above the codes DZXDIM 1FP87
ans this is bellow all the codes BC/CC U9567 192
Any help is greatly appreciated thanks in advance everyone
LS1Tech Administrator
Received 1,724 Likes
Off the top of my head, 19I = Interior trim combo, ebony. And 192 = Ebony leather. Some of the others are plant codes and option groups.
Run your VIN through Compnine.com and most of the RPOs will show up with their definition.
1SZ: Discount Option Package
19I: Interior Trim, Black (I) (91)
SLM: Stock Order, Processing Code
STE: Sainte-Thérèse Assembly Plant
192: Trim Combination, Leather, Black (2) (91 )
6BS: Component Front LH Computer Select Suspension
7BS: Component Front RH Computer Select Suspension
8TJ: Component Rear LH Computer Select Suspension
9TJ: Component Rear RH Computer Select Suspension
BC/CC U9567 192: Base Coat / Clear Coat Exterior Paint Color - Arctic White
Now for the DZXDIM 1FP87 code, I'm not sure. I believe that the 1FP code is saying it's a Chevrolet (1) F-Body (F) Camaro (P), since that's how it shows up in the VIN. I'm unsure as to the DZXDIM part before or the number 87 after. Usually the number after the 1FP is the year it was produced, but yours isn't an 87, so I'm not sure. This is just a best guess though, could be wrong.
http://www.compnine.com/
is the website guys, don't even need to read your RPOs, just put in your vin and viola.
mine also has those odd suspension RPOs, anyone know what they're for?
6ZK COMPONENT FRT LH COMPUTER SEL SUSP (6ZK) SUSP(6ZK)
7ZK COMPONENT FRT RH COMPUTER SEL SUSP (7ZK) SUSP(7ZK)
8TH COMPONENT RR LH COMPUTER SEL SUSP (8TH) SUSP(8TH)
9TH COMPONENT RR RH COMPUTER SEL SUSP (9TH) SUSP(9TH)
(just giving you a hard time. )
